Canon ir 8295. Print and photocopy got dirty line.
  • ktleoh80
    • Mar 2011
    • 21
    Hi everyone. My machine 8295 already change anew primary charging, pre charging ,transfer belt and cleaning blade. But the tiny line still there. Have anyone encounter this issues and how to solve it. Thank you so much.
  • ktleoh80
    • Mar 2011
    • 21
    Re: Canon ir 8295. Print and photocopy got dirty line.
    Printed in a4r
    • Brian8506
      • 1667
      If you're talking about the line at bottom right, it looks like a paper registration or blank area problem.
      • eltarinkderut
        • Sep 2023
        • 2
        Originally posted by ktleoh80
        Printed in a4r
        It seems to me that it is enough to correct everything in the settings and it will work properly
        • ktleoh80
          • Mar 2011
          • 21
          May I know how to resetting,or how to set.? Thank you
          • Brian8506
            • 1667
            Service mode/copier/adjust/feed adj/regist
            • Hishamawada
              • 174
              Stop the sheet before the Fixing , if the issue is visible check the drum assembly .
              Perform a full cleanup to the drum assembly and sensors . if issue stays then it could be developing unit issue .
