Ir advance 6075
  • ARUN MISHRA
    • 80
    [Jamming] Ir advance 6075
    Paper Jam with jam code 0112.
    Some time printing 25-50 sheet than suddenly jam with jam code 0112. Please help I am tired.
    sigpicARUN KUMAR MISHRA
  • jamal121
    • 10
    Re: Ir advance 6075
    Symptom
    0C10/0112/0113 Jam Code due to a piece of paper remained after jam removal
    Description
    0C10/0112/0113 Jam occurred.
    - 0C10: Fixing Toenail Jam
    - 0112: Inner Delivery Sensor Delay Jam
    - 0113: Outer Delivery Sensor Delay Jam
    Cause
    Pieces of paper [a] was not removed completely when jam was removed. Due to thepiece of paper [a]
    remained in the delivery assembly of the main body, jam occurred again.
    • Brian8506
      • 1657
      Re: Ir advance 6075
      Whats the meter count? Could be worn inverter rollers in outer delivery.
      • ARUN MISHRA
        • 80
        Re: Ir advance 6075
        Thank for your valuable feedback. Problem solved now. Internal delivery rollers change. Problem solved now.
