CANON 3525i II Power suply rapair E.Code 808 - 0001
  • CristiI
    • Nov 2023
    • 12
    CANON 3525i II Power suplly rapair E.Code 808 - 0001
    Howdy!
    I am getting error 808-0001.
    There are no problems with the electrical network, erasing the error does not help me, the machine does not reach the working state, printing.
    Somehow the paper gets close to the oven and stays there.
    Acoustically, you can hear two relays from the power supply board, vibrand, short approx. 2 seconds, only at start-up. I mean, that would be an unnatural noise. I tested the board in another car and it does the same. Am faut firmware update, do the same.
    Knowing that the power supply board - low voltage is defective, please help me repair it. A diagram would be very welcome. Or what components did you change for ​this error - clearly coming from the power supply board. Thank you in advance! Cristi tehnicdti@gmail.com
  • ADV COPIER
    Pemain
    • Nov 2022
    • 256
    Re: CANON 3525i II Power suply rapair E.Code 808 - 0001
    Howdy!
    - first check of voltage
    Let's Drink our Coffee
    WhatsApp +62895325228383
