Canon ir c7570i yellow problem
  • Asaadahmed003
    • Jun 2019
    • 25
    [Misc] Canon ir c7570i yellow problem
    Hi all,
    Am facing this weird issue with canon ir c7570i where i don't get any yellow color when printing or sometime i get just a little... When i print test page PG10 i get no yellow what so ever (page 3 on the attachment) and when printing PG4 with only yellow i get lines but not the normal gradient color(page 2 on the attachment)... I did check the drum and development drive unites even the laser unit to no vail.. i tried switching the yellow unit with the magenta unit and got full coverage (page 1 on the attachment).
    Patiently waiting for your replys..
    Best regards
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: Canon ir c7570i yellow problem
    the drums wear at rear side and if left long enough it will start pulling developer
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • Asaadahmed003
      • Jun 2019
      • 25
      Agree ... But however this case is different... I switched the whole yellow drum unit (drum + dev) with the magenta one and got a good yellow output in place of the magenta and no magenta in place of the yellow
      • Venom
        • Nov 2009
        • 765
        The one sample showed yellow bands which looks like a mechanical issue. Maybe the dev unit isn't rotating properly? Write a line with a black marker on both the drum and dev mag roller and see if they are rotating properly. Dev bias losing connection, drum grounding or laser unit could cause light print but isn't likely.
        • Asaadahmed003
          • Jun 2019
          • 25
          Well after several on and off battles with this issue am once again empty handed... Brought another well working machine and started switching every single board to no vail switched all drum drives and developer drives and nothing
          My only option now is to remove and switch the drum holder unit but I can't find how to do so in the manual... So if anyone knows how to i would very much appreciate it
          • mramlawi
            • Jul 2011
            • 838
            seems its hv problem or itb problem have u try a new transfer belt and is this problem happen suddenly or after you change toner is ur toner original
            Distinguished road makes you jewel in rough
            • Asaadahmed003
              • Jun 2019
              • 25
              We did test it's transfer unit on the other machine and tested the othe machine transfer unit in it still the same. Also we changed all hv boards and the main controller to no vail... The toners are OEM ... We bought the machine as refurbished but when we got it, it had this issue
              • hitu
                • Dec 2023
                • 2
                I have 2 Machine With Same Issue.
                • Asaadahmed003
                  • Jun 2019
                  • 25
                  Sorry i don't fully remember how we fixed it but i think it has something to do with the laser control board near the laser units
                  Will check my reports and get back to you
                  • hitu
                    • Dec 2023
                    • 2
                    Thanks And Regards. Plz Help As Early As Possible.
                    • Feroz1272
                      • 1
                      i cheked Laser Drive Pcb But Still Same.
