Canon varioprint image problem
  • smiley
    • Aug 2008
    • 615
    hello guys good day. i want to ask if someone experience or found a solution on this print quality problem. i attached the picture below. Thank you in advance.
    there is no glory without sacrifice
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5018
    Re: Canon varioprint image problem
    Looks like a printhead error. It would help if you knew the Varioprint model.
    • smiley
      • Aug 2008
      • 615
      im sorry i forget to include the model number. its a vario print 115.
      • ninhhung
        • Apr 2023
        • 4
        Electrical tracks on image drum error. You can replace Drum Unit Assy. lol
        • smiley
          • Aug 2008
          • 615
          Hello guys just an update on this problem. We just use pcl6 printer driver and those lines disapprear in print.in copy and ps print still have those problem.
          • copydan
            • Aug 2011
            • 13
            I had an issue like that I cleaned the edge of the drum where an encoder sits. Problem solved.
            • smiley
              • Aug 2008
              • 615
              Hi do you used any cleaner to clean the incoder?
