Canon 1238i II Scan File Name Issue
  • noolds
    • Dec 2023
    • 2
    Hello everyone, I have a very important problem and I need you to solve it. I have a Canon 1238i II model printer. When I scan a file on the printer, I name the file on the printer. However, when I scan, additional characters appear in the file name. For example, the file I named 123456 appears as 123456_0017_231229182412_001.pdf. But for some reasons I cannot accept this. The file name should appear as 123456.pdf on my computer.
    I am asking for help on this matter.
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: Canon 1238i II Scan File Name Issue
    If that model has a button for removing date/time stamp, check it. Otherwise just rename on your pc.
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
    • noolds
      • Dec 2023
      • 2
      No, there is no such option. Is there a way to directly change the printer software?
