Ir advc5045i
  • bomberi
    • 107
    Ir advc5045i
    Hello everyone,
    Happy New year to all.
    I'am doing scan on canon advc5045i ans I have the error E0733-000. I change the scan unit, the DC controler, the main power supply, the controler 1 and 2. I need your ideas on this problem. Thanks
  • ADV COPIER
    Pemain
    • Nov 2022
    • 251
    Re: Ir advc5045i
    Originally posted by bomberi
    Hello everyone,
    update your system software
    Let's Drink our Coffee
    WhatsApp +62895325228383
    • bomberi
      • 107
      Re: Ir advc5045i
      Thank you for your answer,
      I think all will go well when I change the HDD.
      • RicheyRich80
        • Oct 2023
        • 8
        Re: Ir advc5045i
        Hello everyone,
        did you do anything with the bypass/right door connector check that for pushed pins and lastly replace HDD with seagate L41606-011. i have great sucess with those
        • Radiscar
          • Jun 2019
          • 74
          Re: Ir advc5045i
          Hello everyone,
          Just to clarify; the issue only occurs when you try to scan? If you cleared the error and reboot the device, it goes away? If so, does it occur on the glass and/or through the document feeder?
          you could have messed up wiring/connectors and if it only occurs during scanning and not copying or printing you can narrow down what to look for.
