Upper belt and lower belt for Canon imagePRESS C600/650/710 series e V700/800/900.
  • Ingranaggio_rotto
    • Oct 2010
    • 274
    Good evening everyone !
    I need advice from those who maintain the imagePRESS C 600/650/710 and V 700 series.
    They proposed that I rebuild the upper belt and lower belt (the old FM1-C721-000 and FM1-C722-000) with compatible belts...
    Is it worth doing?
    And then do we need to make adjustments to the groups? (due to bad fusion or wrinkles or jams).
    Thank you !
  • khaled_abosere3@yahoo.com
    Head technical support
    • Mar 2012
    • 164
    Re: Upper belt and lower belt for Canon imagePRESS C600/650/710 series e V700/800/900
    Dear:
    I advise you not to do it
    we have done what you want to do but it works just for a very short period and then the belt (upper & lower) is damaged and resulting in a relay board fault
    so replace the unit to overcome problems you may face.
    yours sincerely.
