canon adv c3525i II error e302-00001
  • anas.agha
    • Aug 2023
    • 16
    i have canon adv c3525i with error e302-0001, after i clean mirrors i can scan and copy from adf, but if i put a paper on the glass and close the cover suddenly error appear without press copy or scan . i try reset rcon an same error
    any help pls
  • ADV COPIER
    Pemain
    • Nov 2022
    • 264
    Re: canon adv c3525i II error e302-00001
    Detection Description An access error to the paper front white shading RAM or a paper front white shading value out of
    specification was detected.
    Remedy [Related parts]
    - Harness between the Reader Scanner Unit (UN_BO2/J101) and the Main Controller PCB (UN05/
    J7000)
    - Reader Scanner Unit (UN_BO2)
    - Main Controller PCB
    [Remedy] Check/replace the related harness/cable, connector and parts.
    [Reference] Before replacing the Main Controller PCB, back up the service mode data (approx. 2
    min) and restore the backup data after the replacement so the data may be able to be protected.
    - Backup: COPIER (LEVEL2)> FUNCTION> SYSTEM> RSRAMBUP
    - Restoration: COPIER (LEVEL2)> FUNCTION> SYSTEM> RSRAMRES
    Let's Drink our Coffee
    WhatsApp +62895325228383
    • Saturn
      • Nov 2023
      • 172
      The most common reason is between the Reader Scanner Unit and the Main Controller.
      I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
      • Radiscar
        • Jun 2019
        • 74
        try and scan an empty glass bed.
        try and scan different size paper/orientations
        check how the scan lamp is lighting up when closing the lid
        check the values of the reader controller pcb in service mode if everything is 0...check connections and if they all look good it could be the reader pcb
        I've had the shading error due to extreme dust; you've probably already did but make sure whiteboard, white plate, and both sides of the glass are clean.
        Make sure the scanner is reaching the home position/moving properly
        if the error doesn't occur with a smaller paper size then it's possible you have a faulty photo interrupter but usually you'd get a false paper size recognition.
        The ribbon cable/scanner is the most likely cause though.
        • Saturn
          • Nov 2023
          • 172
          Sorry, some words are missing. I mean: The most common reason is the harness between the Reader Scanner Unit and the Main Controller.
