CANON GP 605
  • xcopytech
    • Aug 2006
    • 1783
    CANON GP 605
    Have E 220.
    Tried to replace scanner lamp but still same.
    Lamp just start to light for moment and then get error code E 220.
    Thanks in advance for inputs.
  • cdvidaceiba
    • 80
    did you clear the error code ?? *28* copier /fuction/clear/error/ok ???
    when you install a new lamp , you got to make some ajustments like ccd adjust
    • roygunawan
      • 12
      replace the heater lamp
      • OJ the Bodge
        • 15
        Check the lamp heater as it may have a small crack in the wiring, which may only open up when scanner is moving.
        Make sure the heater is put on in the correct location as it may block a sensor.
        If the heater does not correct it, try the lamp intensity pcb.
        • infomaxbs
          Trouble Hunter
          • 29
          try to clean the lamp holders (connectors) may be some carbon dust also leads to error e 220
          Failures is the knowledge bank of experiences
          • fr2au
            • Jan 2008
            • 20
            Hi there,
            I got this issue long time ago, replacing the light intensity control PCB resolved it
            Regards
