calibrate duplex printing irc 3220
  • maurimx
    • 116
    Is there a way to calibrate duplex printing from the copier ?
    I get a 2 mm shift up.. the whole image moves 2 mm up.. and its a pain in the a$$ to change stuff in corel or try to move the image when we are trying to print cards of flyers, etc..
    thanks !
  • SCREWTAPE
    • Aug 2025
    If the second side needs to be moved. Adjusting ADJ/ FEED-ADJ/ ADJ-REFE will move the image towards the operator or non operator side of the machine. Sometimes this helps.
    • maurimx
      • 116
      ADJ-REFE positive will move it toward or away ?
      and what will ADJ-REFE2 Do ?? and the other one, the option in the middle do ????
      • SCREWTAPE
        • Aug 2025
        ADJ-REFE-Used to adjust the horizontal registration during re-feed. Adjustment method - Increasing the value by 1 moves the image 0.1 mm away from you.
        REGIST-Used to adjust the registration roller clutch ON timing. Adjustment method - Increasing the value by 1 moves the image by 0.1 mm in the direction of the leading edge of the paper.
        REGIST2-Used to adjust the leading margin on the second side when making a doublesided
        copy. Adjustment range -50 to 50 (0.1mm unit)
        I'm not saying that this will solve your problem or maybe it will. Just print out a P-print first so that you have the original specs before you start tweaking.
