4535i internal sorter info needed
  • fshead
    • 2376
    greetings
    i dont service Canon much but have an accnt who took in a closed neighbors canon imagerrunner advance.
    I was there last to service their Ricoh colors and took a look at it.
    it seems like there is a minisorter jam but i could not release the sorter with engaging the lever.
    Does the sorter pull out to front,side?
    maybe pics would help..
    thanks in advance
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5007
    Re: 4535i internal sorter info needed
    I was also confused for the first time. The Japanese blew it with this model. You need a screwdriver!
    • fshead
      • 2376
      ok.
      So what gets unscrewed and does it pull out to the left or towards the control panel..
      • fshead
        • 2376
        hey thanks for the help canon guys...
        i am glad i dont need to deal with this shitty bunch
        • Saturn
          • Nov 2023
          • 171
          Canon is not bad as it seems, but this sorter is
          I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
          • fshead
            • 2376
            ok
            1
            can it be removed as an option?
            i fix things if possible but dont need headaches or having to learn a machine i will never see again
            • Saturn
              • Nov 2023
              • 171
              It's an option and it can be removed.
              If you give me a mail adress, I will send you the manuals.
              • fshead
                • 2376
                thanks i just want to get this machine in the loop for a good account.
                • Canuck
                  Tech Specialist
                  • 1713
                  Did you get it removed? Simple to remove these from machine..under 3 min...lol. Open front cover, thumbscrew to remove bracket for starters..
                  • fshead
                    • 2376
                    hi
                    no I had 4 other machines non canon to do part calls on and my meter in the street had me on a tight window.
                    also this is a free favor to a good account..on ricohs the internal sorter comes out two screws and a bracket..
                    i have not touched a canon in 10 years...when i first started copiers i did do some CLC500 LIQUID MACHINE..Do not miss that
