can i get the system software for IR2200 ???????
  • koky5500
    • Oct 2025
    dear all
    i have iR2200 coper and a had trouble with the hard disk so i change it but i do not have the system software for it can i get this please. i have allredy the SST4.11e in the computer and i conect the coper with LPT1 in ECP mode and the coper in the download mode by pressing 2+8 so i gust need the system soft can eny body send it to me PLEASE
    my email is ( koky5500@hotmail.com or koky5600@yahoo.com )
    Thank you very much in advance.
  • bnmand
    • Sep 2008
    • 383
    Originally posted by koky5500
    dear all
    Is your iR2200 copier networked? If it is you should see a NIC on the right hand side of the copier. If it is you need the N firmware. If it isn't networked you just need the ordinary firmware. The iR2200 copier is in the same series as the iR3300 (ir2200 is low end, iR2800 is high end) and uses the same system software. The new hard disk for iR3300 has lots of useful information.
    Depending on which hard drive you got you may need to modify the HDFormat.ift file (assuming you're able to get the firmware).
    • koky5500
      thank u Mr.bnmand for ur reply
      so can u tell me from whar i can get the firmware for ir2200 and it is not networked
      • rosaro75
        • Mar 2009
        • 87
        check your mail. link has been sent to you
        • raj_chil
          Regarding ir3300 system software and the procedure
          Hi guys,
          I think my ir3300 needs HD format as it is showing 602 code.after surfing through this site i came to know that i need system software and sst. I some how downloaded sst 4.11e with the help of this site but i need system software.
          Can someone forward me the system software for IR3300 and the suitable sst version to rajchilivery@yahoo.com raj.chilivery@gmail.com.thank you guys in advace
          • bnmand
            • Sep 2008
            • 383
            Originally posted by raj_chil
            Hi guys,
            A HD format may work, but even if it does the hdd will almost certainly need replacing soon.
            • sabinshresth
              Plz send me also the firmwire of IR2200 i need it sir ..plz help mee and cannon support is also not near to my place it is very far
              sabinshresth@gmail.com
              thank you
