Image data when the Copy Function is lose
  • zawmyo201210
    • Oct 2022
    • 51
    [Misc] Image data when the Copy Function is lose
    I have a 4570 copier that I have been sitting idle.
    When using it again, it shows error codes E-00732/733 when power is turned on. I cleaned the DC controllers in my machine. I also cleaned the reader scanner unit and tried again. The error code is no longer displayed. It went ok.
    What happened again was that the (((( copy function )))
    data I was supposed to back up was lost. I can't reproduce it in any way.
    In the SERVICE MANUAL book, the Copy UI in service mode 2 also shows (1) so I rescheduled a Main Controller board. It's the same.
    Please suggest what else I can do, experts.
  • ADV COPIER
    Pemain
    • Nov 2022
    • 262
    Re: Image data when the Copy Function is lose
    try replace flat cable DC to reader
    Let's Drink our Coffee
    WhatsApp +62895325228383
    • zawmyo201210
      • Oct 2022
      • 51
      Yes, I am change Dc to Mn board flat cable . But I am same error.
      • ADV COPIER
        Pemain
        • Nov 2022
        • 262
        If the DC PCB is damaged, try replacing it
        • Peter Sim
          • Sep 2008
          • 445
          Replace Reader Board
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5018
            E732 means that the configuration of the machine has been changed. You have something disconnected, or the device does not detect a unit.
            • zawmyo201210
              • Oct 2022
              • 51
              ((( I am change new Flat cable. It's okay. )))
              Another problem is that when the machine has a paper jam, the error system does not go away. I power off the device and turn it back on and it's fine. I looked for this error in the service manual and did not find it.
              How can I find the error after I turn off the power display? Please help me.
              • MOLICN
                • Mar 2024
                • 26
                Your situation: Similar to firmware upgrade failure causing data loss in scanning the motherboard PCB.
                This issue can be fixed by attempting a forced upgrade to fix the data
