Dear: Greetings, I would like to tell you the following.
I have a 6570 machine that is making my copies very clear. I have changed new filaments in all the crowns, I have cleaned mirrors, laser, etc. and nothing has worked.
I have another one that is working perfectly well and I even changed the entire cylinder unit, developing unit, and crowns and it didn't change at all.
I have disabled the power controller and it worked perfectly fine for both copies and prints.
The question is the following: What happens if I continue working with the power controller with a value of 0? Will there be any consequences?
I have already changed other power controllers and everything is still the same.
Suggestions?
thank you so much
greetings,
Suggestions?
thank you so much
greetings,
