problem with canon c1127i and canon mf453
  • enricocopyline
    • Jun 2018
    • 122
    I have a problem with Canon compatible toners with the C1127i multifunction but also with the Canon MF453.
    the problem is that they detect the compatible toner, always giving me the message when I turn it on with the various problems...
    is there a way to remove the toner check?
    or toner controls in general?
    thanks for the replies
  • Saturn
    • Nov 2023
    • 171
    Re: problem with canon c1127i and canon mf453
    What are the problems exactly?
    Do you use original toners and the machines detect compatible toners, or do you use compatibel toners and the detection ist correct?
    I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
    • enricocopyline
      • Jun 2018
      • 122
      I use compatible toners and would like not to always have the compatible toner not recognized message
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5012
        interesting title "problem with canon c1127i and canon mf453"
        You have a problem with cheap cartridges.
        Even though it is compatible, it should not be not recognized. Contact the cartridge seller.
        You can't turn it off.
        • Brian8506
          • 1664
