Canon ir adv C3525
  • CrapAimer
    • 296
    Canon ir adv C3525
    Service error E748-2024 any help very much appreciated.
    Thanks in advance
    George
  • Saturn
    • Nov 2023
    • 172
    Re: Canon ir adv C3525
    The service manual says:
    748-2024-00 - Main Controller PCB access error
    Detection Description - Main controller board access errors
    Remedy - Check/replace the Main Controller PCB
    I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
    • MOLICN
      • Mar 2024
      • 26
      Your fault is that the FLASH electronic hard drive data is damaged and requires the use of FLASH repair tools.
      Do you have FLASH tools? If not, it is necessary to purchase FLASH again.
      This can be repaired, but it needs to be sent for repair and requires some shipping costs. You have to consider it yourself.
