TCP Sequence Number Approximation Based Denial of Service - Canon c3835i
  • dbarr1997
    • Mar 2024
    • 3
    [Misc] TCP Sequence Number Approximation Based Denial of Service - Canon c3835i
    Hi All,
    First post here!
    Does anyone know about resolving TCP Sequence Number Approximation Based Denial of Service -CVE-2004-0230 Vulnerability on a Canon Imagerunner Advance DX device? Not sure if there even is a fix for this. Included some more in depth info below. Any help will be greatly appreciated!
    More info:
    CP provides stateful communications between hosts on a network. TCP sessions are established by a three-way handshake and use random 32-bit sequence and acknowledgement numbers to ensure the validity of traffic. A vulnerability was reported that may permit TCP sequence numbers to be more easily approximated by remote attackers. This issue affects products released by multiple vendors.
    The cause of the vulnerability is that affected implementations will accept TCP sequence numbers within a certain range, known as the acknowledgement range, of the expected sequence number for a packet in the session. This is determined by the TCP window size, which is negotiated during the three-way handshake for the session. Larger TCP window sizes may be set to allow for more throughput, but the larger the TCP window size, the more probable it is to guess a TCP sequence number that falls within an acceptable range. It was initially thought that guessing an acceptable sequence number was relatively difficult for most implementations given random distribution, making this type of attack impractical. However, some implementations may make it easier to successfully approximate an acceptable TCP sequence number, making these attacks possible with a number of protocols and implementations.
    This is further compounded by the fact that some implementations may support the use of the TCP Window Scale Option, as described in RFC 1323, to extend the TCP window size to a maximum value of 1 billion.
    This vulnerability will permit a remote attacker to inject a SYN or RST packet into the session, causing it to be reset and effectively allowing for denial of service attacks. An attacker would exploit this issue by sending a packet to a receiving implementation with an approximated sequence number and a forged source IP address and TCP port.
    There are a few factors that may present viable target implementations, such as those which depend on long-lived TCP connections, those that have known or easily guessed IP address endpoints and those implementations with easily guessed TCP source ports. It has been noted that Border Gateway Protocol (BGP) is reported to be particularly vulnerable to this type of attack, due to the use of long-lived TCP sessions and the possibility that some implementations may use the TCP Window Scale Option. As a result, this issue is likely to affect a number of routing platforms.
    Another factor to consider is the relative difficulty of injecting packets into TCP sessions, as a number of receiving implementations will reassemble packets in order, dropping any duplicates. This may make some implementations more resistant to attacks than others.
    It should be noted that while a number of vendors have confirmed this issue in various products, investigations are ongoing and it is likely that many other vendors and products will turn out to be vulnerable as the issue is investigated further.
  • ADV COPIER
    Pemain
    • Nov 2022
    • 269
    Re: TCP Sequence Number Approximation Based Denial of Service - Canon c3835i
    What do you mean, does your machine not have IP via DHCP? Or is your machine blocked by the router?
    Let's Drink our Coffee
    WhatsApp +62895325228383
    • dbarr1997
      • Mar 2024
      • 3
      Machine is fully functional and on the network - No problems there. Its a security vulnerability so essentially could be open to attack. Wondered if there was a patch for it yet that anyone had come across?
      • ADV COPIER
        Pemain
        • Nov 2022
        • 269
        I have never encountered a case like malware on a Canon machine, maybe you can add a firewall to your router for outgoing connections, you can close it or you can use dynamic ports
        • dbarr1997
          • Mar 2024
          • 3
          Thanks for your help, much appreciated!
          • ADV COPIER
            Pemain
            • Nov 2022
            • 269
            you welcome
