Office365 Scan to Email C5250 setting
  • lionex3d
    • Jun 2013
    • 41
    anyone have a detailed guide on setting up a C5250 machine (fw v54.58)
    to use office 365 account with *app password*.
    Office 365 Primary Server: smtp.office365.com
    Port: 587
    Secure Socket Layer: On
    Reply E-mail Address: [Username]@[DomainName].com
    SMTP Auth: ON
    Username: [Username]@[DomainName].com
    Password: [Password]
    network test using GMAIL with port 587 is working flawlessly.
    once I shift to Office 365 accounts, it will prompt *SMTP Authentication Error*
    app password is copy-pasted to prevent typo error.
    would appreciate any tips.
  • ADV COPIER
    Pemain
    • Nov 2022
    • 264
    Re: Office365 Scan to Email C5250 setting
    try this, hope it helps
    pop3 : 995
    imap : 993
    smtp : 465
    Let's Drink our Coffee
    WhatsApp +62895325228383
    • lionex3d
      • Jun 2013
      • 41
      pop3 : 995
      imap : 993
      smtp : 465
      need to use 587 for TLS 1.2
      based on the guideline from microsoft
      • ADV COPIER
        Pemain
        • Nov 2022
        • 264
        try update your firmware
        • Saturn
          • Nov 2023
          • 172
          Port: 587
          SMTP Auth: ON
          We also have these settings at a C5560i with only one difference, instead of SSL we have TLS. Does the machine have the latest firmware installed?
          I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
          • lionex3d
            • Jun 2013
            • 41
            not at the moment, the latest version I can get from the server is v60.something, which is released around year 2020, I'm still trying to source for newer one.
            I believe I have a 5535i, so I might try it on that one.
            I have read somewhere that this can be done via relay, still looking for a "guide for dummies" for that one yet.
            hopefully someone can confirm here that all I need is the latest firmware.
            • ADV COPIER
              Pemain
              • Nov 2022
              • 264
              you can update from CDS, or check the PM
              • zoraldinho
                teacher-guide-expert-guru
                • Mar 2008
                • 5018
                Did you turn off two step verification on your office account?
                • Saturn
                  • Nov 2023
                  • 172
                  [ATTACH=CONFIG]62126[/ATTACH]
                  You can update the firmware via the service mode of the machine if it is connected to the internet.
                  • MOLICN
                    • Mar 2024
                    • 26
                    The last version firmware number of this machine is: usb_iAC5255_20231015.0610201.zip
                    Update time: October 15, 2023
                    I feel that your problem is caused by the email port not being set correctly. It is recommended that you use the email client to test the port data on your computer first to determine if it is set up correctly.
                    It is recommended to use tools such as DreamMail and FOXMAIL for testing.
                    • lionex3d
                      • Jun 2013
                      • 41
                      I haven't, but I thought that using the "app password" will bypass this security feature. same with Gmail accounts.
                        • 37628
                        Port: 587
                        SMTP Auth: ON
                        How to set up a multifunction device or application to send emails using Microsoft 365 or Office 365 | Microsoft Learn
                          • 37628
                          Microsoft 365 or Office 365 (SMTP relay) is Option 3 in the link I just posted.
                          • lionex3d
                            • Jun 2013
                            • 41
                            yes, I found this link also. but still trying to find a more detailed tutorial/video tutorial as I am not skilled enough on office365 administration.
                            • lionex3d
                              • Jun 2013
                              • 41
                              Will update this post on Monday, once I tried the other suggestions.
