Canon IR ADV C5255 error code E355-004
  • Jocelyn
    • Mar 2024
    • 10
    hello, the network card of my canon IR ADV c5255 does not work, I want to replace it with a card taken from a Canon IR ADV c5235 and it shows me error E355-0004. can anyone tell me if this can work and how to remove this error.thanks
  • ADV COPIER
    Pemain
    • Nov 2022
    • 258
    Re: Canon IR ADV C5255 error code E355-004
    pcb not sync
    try update firmware to sync
    Let's Drink our Coffee
    WhatsApp +62895325228383
    • Jocelyn
      • Mar 2024
      • 10
      hello so if I understand correctly, by upgrading the firmware the error will be cleared and the card taken from the IR ADV C5235 will be able to work on the canon IR ADV C5255
      • Brian8506
        • 1665
        The 2 little boards on the main controller need to stay with the machine. Put the original counter and serial number pcb back with the original machine.
        • Saturn
          • Nov 2023
          • 171
          This will not work, as there is a different controller for each model depending on the printing speed.
          FM0-0350-000 > iR ADV C5255
          FM0-0351-000 > iR ADV C5250
          FM0-0352-000 > iR ADV C5240
          FM0-0353-000 > iR ADV C5235
          I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
          • Brian8506
            • 1665
            I missed the different model part. Even if you have the same model machine the small boards need to stay with the original machine
