iR 5050 drum
  • roho
    • Mar 2009
    • 844
    iR 5050 drum
    I have a drum with some lines/marks-is it possible to polish these marks from the surface? I've heard drum powder with alcohol may work.
    Any suggestions?
    TIA
  • 11x17
    • Apr 2007
    • 153
    i have polished many ASI drums with drum powder and depending upon the severity of the marks you will probably get them out.
    • SCREWTAPE
      If they are scratches forget about it.
      • Canuck
        Tech Specialist
        • 1713
        I use Vim to polish all Canon ASI drums(also use on CLC OPC drum)....works like a charm. Is it the drum or cleaner blade...flip the blade
        • kuby
          • Oct 2007
          • 1410
          I use Brasso, pads and a circular motion. Works great.
          • Kopyrtek
            Copier Psychologist
            • Jan 2007
            • 407
            I've used both and the Brasso is easier to use.Although i am getting used to the powder that Canon has.
