Good day all, please give some idea how to solve this problem, toner sensor changed but still appear this problem after some copies
iR2270 error E024-0001
They are two TS sensors, one on the developer and by the sub hopper in the inside rear of the machine. Check the wire harness. Cut any wire ties you can. Clean out the developer. Make sure you are using geniune canon toner and check DC. -
Thanks for your advise, we never use compact toner, not reliable and a lot of problemComment
