Cannon copier CLC 950 error code 014
  • dgoldsworthy
    I have an older Cannon color copier it worked fine until this morning. It powers up but will not copy and displays error code 014. Has anyone seen this before?
    tks,
    Dave
  • dcycle
    • Sep 2006
    • 37
    CLC950
    Are you sure it is not E014 code??
    David
    Only two defining forces have ever offered to die for you:
    1. Jesus Christ
    2. The American G. I.
    One died for your soul, the other for your freedom.
    • dgoldsworthy
      [quote=dcycle;5928]Are you sure it is not E014 code??
      David It is E014. Do you have any suggestions?
      tks,
      Dave
      • dcycle
        • Sep 2006
        • 37
        CLC950
        The following is directly out of the manual:
        Cause:
        The fixing motor (M5) is faulty
        The fixing motor drive system is subjected to an overload.
        The DC driver PCB is faulty.
        The CPU PCB is faulty.
        Possible fix:
        0000 The motor lock signal (FXMLK) is "0" for 1 sec or more while the fixing motor is rotating. Check to see that the fixing motor is turning as required.
        David
        1. Jesus Christ
        • autonut
          Fixing drive error
          The self diagnostic has failed to see proper rotation of the fixing assembly. It is likely that it is jammed up by something. The likely problem is teh web which is the white cloth which helps to lubricate evenly the uppper fixing roller.
          Hope this helps
          • dgoldsworthy
            [quote=dcycle;5932]The following is directly out of the manual:
            Cause:
            Possible fix:
            David[thanks for the help]
            • dcycle
              • Sep 2006
              • 37
              Web belts have caused many different problems in machines that use them, Xerox, canon, etc. Check the belt to see if it is tracking straight and not binding.
              David
              1. Jesus Christ
