Canon iR3300 HDD Softwares Installing Problem
  • mitsubee
    • 176
    Hi all techies,
    I have some problem with new HDD that has to be install after my Canon iR3300 crashed ( e602-0001 ) , I tried alot of HDD's but when after i click FORMAT at the All Partition Button... It will tell me HDD does not match , Cause/Action : Please Check your format files *.ift , i wonder what actually happened? incompartible version of FORMAT files or it's HDD is not usable other than the original one.
    I have few FORMAT.ift file such as 0007 , 0012 which all can;t use to format.
    Can any one here Help to explain the actual issue of this?
    Does cloning Help?
    Thanks in advance.
    Cal
  • bnmand
    • Sep 2008
    • 383
    See document posted by Oze: Copytechnet.com
    There are a list of say roughly 50 hard drives or so supported in a HDFormat.ift file. You can open the ift file using a text editor. The document above outlines how you can try and use hard drives not found on the list. Use the latest version of the HDFormat.ift file that you've got. It should give the list that is most likely to work with your drive. The most recent version I've heard of is version 15.
    Hopefully at least one of the drives you've got will work with the method outlined in the pdf.
    Other than that make sure you are using a IEEE1284 bi-directional parallel cable (such as was commonly used by scanners years ago) and that the parallel port of your computer is set to use ECP mode. This setting needs to be set in the BIOS (usually accessed soon after you press the power button to start your machine, by pressing a button such as F10) and in the device settings in Windows. Alternatively if you have one, you can try using a nethawk (special Canon usb to parallel that is no longer produced) cable.
    Hope this helps.
    It is best to use SST if you can. As a last resort, if you have access to a working copier in the IR2200 series (an IR2200, 2800 or 3300 not i versions) you can try cloning the hdd. I don't know how, but others report it working.
    • kuby
      • Oct 2007
      • 1410
      Here are the ones supported by the ir2200 series....
      Fujitsu MPC3032AT
      Fujitsu MPD3043AT
      Fujitsu MPE3064AT
      Quantum FireBall CX6.4A
      Quantum FireBallLct10 05
      Quantum FireballLct08 04
      Quantum FireBallLct15 07
      Fujitsu MPF3102AT
      Toshiba MK6014MAP
      Toshiba MK6015MAP
      IBM-DJSA-205
      IBM-DARA-206000
      Fujitsu MHK2060AT
      Seagate ST34311A
      Seagate ST34313A
      Seagate ST310211A
      Fujitsu MPG3102AT E
      Quantum FireBallLct20 10
      Toshiba MK1016GAP
      IBM-DJSA-210
      Hitachi IC25N006ATDA04-0
      Hitachi IC25N010ATDA04-0
      Fujitsu MHN2300AT
      Toshiba MK6017MAP
      Maxtor 2B020H1
      Maxtor 4K020H1
      WDC WD300AB-00BVA0
      Samsung SV2001H
      Maxtor 2F030J0
      ExcelStor Technology J120
      Samsung SV0211H
      Seagate ST340015A
      Toshiba MK2023GAS
      Samsung SV0221N
      Toshiba MK2023GAS
      Seagate ST92011A
      • mitsubee
        • 176
        Thank for replying , but the cause wasn't No HDD Found...Is The HDD is NOT Match , i tried using Oze way...that was really cool but it still Dose Not Match. Hopefully you all great Guru's could help.
        Thanks a Million
        Cal
        • bnmand
          • Sep 2008
          • 383
          Thanks a Million
          Cal
          Did you remember to increment the count for the number of hard drives in the ift file when adding your entry in?
          What version of SST are you using? I read somewhere that 4.11E has some problems, particularly with doing a HDFormat. I'd have a go at using an older version of sst. Use the latest system software you have though.
          • mitsubee
            • 176
            I had extend the HDD from 45 to 46 DONe..still problem.....i'm using a 3.02e. Or maybe i just need a XXxx0013.ift to support it....can you send to me brother...?
            calvin5522@gamil.com
            Thanks.
            • bnmand
              • Sep 2008
              • 383
              Thanks a Million
              Cal
              The HDD not found refers to HDD not being in the HDFormat.ift file I think. This could also be expressed as it not matching one of the drives in the list. If your drive is not in the HDFormat.ift list of drives you must use the procedure outlined in the HDD Not Found PDF or formatting the drive definitely won't work.
              • SCREWTAPE
                • Aug 2025
                Thanks.
                You need a XXxx0013.ift file to format the HDD otherwise you will never succeed. Any other file is not supported for the 3300.
                • mitsubee
                  • 176
                  Could someone kindly send me that XXxx0013.ift file please..... or anylink so i could download it ?
                  calvin5522@gmail.com
                  Thanks in advance.
                  • bnmand
                    • Sep 2008
                    • 383
                    Thanks in advance.
                    The 52 drives in the HDFormat v13 list aren't easy to come by. So don't forget to use the SST HDD not found pdf to add a drive to this list if you can't find one. Try and get as close specs as possible to a similar drive, that's on the list and from the same brand. Of course you'll probably have to get a higher capacity drive, but that can't be helped. Whatever you do, don't get a smaller capacity drive.
                    If you haven't used the v13 list yet and you've already got some drives, I'd try at least some of them first before going out and buying more drives.
                    • mrfixit51
                      Lead Service Technician
                      • Oct 2008
                      • 1975
                      Some additional info...
                      One of the things that escapes most peoples attention about this list is that it is really generic in nature. Most of those drives are antiques now Canon did not specifically test all those drives on the list to work with the 3300,,, but more likely it is a broad list of models that have been tested against the whole older fleet of imagerunners at the time of manufacture. There are 3.5" hard drives in that list,,, and they simply will not work in that application. When I was altering the list 5 years ago, I simply replaced one of the older models on the list with my test subject drive info. I did not run afoul of any list length problem that way.
                      • kuby
                        • Oct 2007
                        • 1410
                        I made the list from the inf file, I did not check to see if what size the drives were. I simply read the drives that were on the inf file for that model.
                        • sabinshresth
                          Plz send me also the firmwire of IR2200 i need it sir ..plz help mee and cannon support is also not near to my place it is very far
                          sabinshresth@gmail.com
                          thank you
                          • bnmand
                            • Sep 2008
                            • 383
                            thank you
                            There's no need to ask for this in several different threads, some of which are not even related to the machine. If you have any problems using the sst let us know. Please be aware that not any drives will work even with editing the file containing the list of hard drives.
                            • rosaro75
                              • Mar 2009
                              • 87
                              thank you
                              see your mail. link is there
