IR-3220 PS driver problem
  • copyhere
    • May 2009
    • 112
    Has anyone ever seen this? Printing with PCL5 driver is fine but when printing with postscript drive the registration is off by 1 inch shifted to the left. I am using the latest ps3 driver and tried an older ps3 driver and the same thing. The machine has the internal canon print board not the c1.
    I recomend to customer to get c1 because I dont know how to fix this problem. It does the same thing from any program and windows test page. Any Ideas? Thanks in advance.
  • mtk525
    • Sep 2008
    • 8
    Is your default paper size set to A4 and not LTR?
    • copyhere
      • May 2009
      • 112
      12X18
      Im not sure what you mean by the default paper size? I was printing on 12X18 paper. When using the pcl driver it prints ok. When using the ps driver the image is shifted to the left 1 inch looking at it in portrait position,and has a 1 inch white border down the right side. The windows test page on letter paper did the same thing. would it being set to A4 also affect the 12X18?
      • mtk525
        • Sep 2008
        • 8
        I am not sure about 12 x 18 paper, but under printing preferences, the PS drivers have been defaulting to A4 lately. And yes the image even on test pages will shift up and cut off the top part of the test page until you change the default to LTR.
        • copyhere
          • May 2009
          • 112
          thanks
          Thanks for your help. I will check that out and see what happens.
          • Canuck
            Tech Specialist
            • 1713
            Sounds like something not configured right...set for full bleed(12x18) on driver...are you send job by paper size or paper tray...fit to scale checked...only emulated postscript anyway
            • copyhere
              • May 2009
              • 112
              need to check
              Thanks for the extra tips I need to spend more time checking those things out. but really they need to get the c1 to do the jobs they are doing. I will post back anyway if I find the solution. Thanks again.
              • nivssluck
                • May 2008
                • 228
                If pcl5 is working fine so be it...
                • alex@wocltd.com
                  • 430
                  why do they need to get the rip?($$$$$$$)
                  will you support when it falls over?
                  • copyhere
                    • May 2009
                    • 112
                    c1
                    They had been using the pcl driver all along but then when they seen the quality improvement of the printed image with the ps driver. They want to use that. I know getting them a c1 will need to be supported.
                    • nivssluck
                      • May 2008
                      • 228
                      IRC 3220 internal board printer? I never use pcl or ps for this printer. I use UFR.
                      But if you want a quality output, you are correct C1 is good.
