I have a Canon IR C3220 with a strange problem. If you put a stack of originals in the df, it will scan some (between 3 & 20) with perfectly. Then suddenly the scanner will "jump position" and start scanning from about the middle of the glass consistenly(but it never errors out) and obviously gives you just the bottom part of the copy. I'm thinking scanner motor. Any thoughts on this?
Canon IR C3220 scanner "losing time"
Scanner loses home position...
I assume if you stop the job and restart it, it will initially work o.k. till the binding condition occurs. Check your transport mechanism for possible binds or loose cog belt. It could also possibly be in the scanner drive motor. Let us know what you find out!"Once a King, always a King, but once a Knight is enough!"
Scanner home position
I would clean and lub the scanner rails with scanner lub oil CK0451.Failing that I have also had this due to a faulty scanner motor.
You're lucky to get the doc feeder to feed that many originals,they usually jam after 5 originals.Comment
I have a Canon IR C3220 with a strange problem. If you put a stack of originals in the df, it will scan some (between 3 & 20) with perfectly. Then suddenly the scanner will "jump position" and start scanning from about the middle of the glass consistenly(but it never errors out) and obviously gives you just the bottom part of the copy. I'm thinking scanner motor. Any thoughts on this?Comment
lost home position
Hey, start with your basic optics service . mr fix it and screwtape are telling you to "back up" i like the "hps" line with this box. although the "slipping" timing disc by mtk525(sorry it just appeared) is easy enough to ck. is rare, in i experience, do your cln/lb then "swap out the "hps" good luck!!! gpbearIT IS BETTER TO REMAIN QUIET AND BE THOUGHT A FOOL
THAN TO SPEAK AND REMOVE ALL DOUBTComment
I've done this plenty to fix the same issue...and if all else fails order a new motor as it comes with the disc.Comment
Thanks for some great insight. I sort of ruled out the HP sensor for now since machine will home if you turn it off and on. I am going out this week to check for binding & the scanner motor disk. I will let you know the results. Thanks againComment
