clone HD on IR series
  • eyalos
    • Aug 2025
    hi guys
    is there any why i can clone the HD for my printer IR 2270 ??
    i try with ghost and clonzilla
    and they no recognise the HD
    Eyalos
  • alex@wocltd.com
    • 430
    if you break the encryption - you win the prize - as yet can't do it, been tried it's a 'hidden partion' all XX70 machines are the same
    • mtech
      • Mar 2007
      • 307
      Try Acronis.
      • mtech
        • Mar 2007
        • 307
        Oh yeah, Use sector by sector. Even if it can't see the data it should copy it anyway. Just a thought.
        • philiptam
          • Dec 2007
          • 11
          Just buy a cloneing machine then you can settle all you CAnon,Ricoh,Xeror,KM,Sharp,all brand,And all model , cost about 1K ,if you neet more info ,just mail me at lbs_pg@yahoo.com
          • ymmtech
            • Jun 2009
            • 190
            clonning ir hd
            It is easy.WinHex will do that. you must clone sector by sector physically.
            First save your HD image to files. then transfer this image to new HD.
            Note that if your origin HD is 15H (head), new HD should also 15H. so with 16H.
            The image file is quite big.you may think of some way to reduce size,(compress,or delete unwanted data,or others). Partition information is at first 63 sector. Each partition header have a unique 12 byte data.
            • alex@wocltd.com
              • 430
              i've tried sector by sector with acronis and then xxclone ,forensic replicator etc still all fail....
              you'll end up with with what seems like a valid 'image' an then copy across and verified to end up with e602
              have you used win hex on a xx70 drive?
              • philiptam
                • Dec 2007
                • 11
                The machine that i have you can clone all HDD for All Brand and model HDD ,don't neet Software what you neet is just a good condition HDD than you can do the clone , 50G HDD you can finish in 20 min
                • ymmtech
                  • Jun 2009
                  • 190
                  I am the guy who knew little about SST, of couse noway to access these info.
                  Weeks before I thew Copytechnet, I use to backup few sets HD image of Ir305 IR3300. When a bad sector occur comfirmed, just get a similar HD, restore the HD image to the drive. It works. I even successfully startup the IR305 printer from a CF mem. And rencenlly, thanks to haydar64, with ir2200 firmware, a little modification on HDFormatXXX.itf, I can make this machine boot up from a CF mem. Althought CF mem is a bit slower then HD, it has a faster seeking time. I think CF mem is an allternative way of replace faulty HD. Currently I am using X133 speed.
                  • mrfixit51
                    Lead Service Technician
                    • Oct 2008
                    • 1975
                    Compact Flash?
                    What is the capacity of the compact flash card?
                    • copyhere
                      • May 2009
                      • 112
                      self image
                      Try selfimage it works for me any hard drive. May not be able to format with sst if hard drive is not compatable with sst. but allows you to use a larger hard drive than the original.
                      • ymmtech
                        • Jun 2009
                        • 190
                        Answer to Mr mrfixit51
                        It is a 8G CF mem. I think a 4G maybe ok but not yet try. I'll tell you when I can confirm this.
