DADF-U1 intermittance showing paper jam at SR1 (jam code 0003)
  • teohcheehooi
    • Dec 2008
    • 12
    Need help on above issue. FYI only single side scanning having this issue.
  • SCREWTAPE
    • Jun 2025
    There has been a case where the pick up and registration clutches (CL1 and CL2) where replaced to resolve jam 0003 and 0004, FK2-6870-000.
    Both have the same #.
    • teohcheehooi
      • Dec 2008
      • 12
      Hi there Screwtape.... will back to u once i proceed to change the registration clutch.
      & will let u know the outcome... THANKS VERY MUCH. (^^,)
      • teohcheehooi
        • Dec 2008
        • 12
        Dear screwtape, thanks for you helps, after replace the clutch the problem was solved. THANK YOU VERY MUCH !
        • Joe Karanja
          • Jun 2009
          • 12
          I believe all you need to do on that is proper service ensuring all sensors and rollers are clean.
