Gp605 cannot boot up
  • petrus
    • 155
    MY FRIEND THIS IS MY GP605 CANNOT ON. I MEAN THE MACHINE CANNOT BOOT UP.
    FOR YOUR CLUE, THE SCREEN IS ON BUT THE MACHINE NOT START AT ALL.NO MESSAGE ON SCREEN ONLY THE LCD LIGHT TURNS ON.
    I HAVE TRIED CHANGE THE POWER SUPPLY PCB, THE I/O PCB, THE IPU PCB AND ALSO THE CONTROL PENAL FROM KNOWN GOOD MACHINE. I CHANGE THIS PARTS ONE BY ONE TO IDENTIFY WHICH ONE PARTS IS FAULTY.
    UNFORTUNATELLY I STILL CANNOT SOLVED THE PROBLEM.
    IF ANYONE CAN HELP?REALLY APPRICIATED.
    THANKS.
  • mrfixit51
    Lead Service Technician
    • 1975
    You state that there is nothing on the screen?
    You state that there is nothing on the screen, not even the Canon progress bar? If that is the case I advise you to try swapping the boot rom with your other copier to see if that will get you going. Initially, all activity occurs from info stored on the boot rom, including the progress bar and logo.
    • petrus
      • 155
      thanks mrfixit for your respond,
      however i can't find the boot rom that you mantioned. is it mounted on the IP pcb or on the MFC pcb?
      I have check on my service manual but the things I not found.
      can you give me more clue of it?
      thanks.
      • j2980kh
        • Mar 2009
        • 69
        boot error ...
        HDD disk error...
        • ninja copy
          Copier repair
          • Mar 2008
          • 24
          1.Remove hhd. in MFC
          2.Fotmat on the windows.
          3.Put back
          There is no firmware on the hdd.
          Electronics technician professional
          • mrfixit51
            • 1975
            My apologies for inaccurate advice...
            Originally posted by petrus
            thanks mrfixit for your respond, however i can't find the boot rom that you mantioned. is it mounted on the IP pcb or on the MFC pcb?
            can you give me more clue of it? thanks.
            Hello petrus,
            Please disregard my message from yesterday, I was mistaken about the boot rom, I was thinking the of copier in terms of the iR5000, and had forgotten how different the iR600 was from that machine. You are correct in that there is no boot rom to be found, sorry. You said you had the manual,, so I would suggest looking at the loss of DC power as a starting point.
            mrfixit51 having another senior moment
            • petrus
              • 155
              I have try change the HDD with new one but it still not wake up.
              it still dead....have you any idea?
              • jprecht
                • Dec 2008
                • 104
                dead
                hey, did u try another hdd from a wking box??? if you changed hdd are you sure it had firmware loaded?? this sounds suspiciously like a firmware issue. j ninja says there is no firmware on hdd ??? have reloaded many canon hdds cannot say on this particular box good luck also did you try to modify to a netwk bx?
                IT IS BETTER TO REMAIN QUIET AND BE THOUGHT A FOOL
                THAN TO SPEAK AND REMOVE ALL DOUBT
                • ninja copy
                  Copier repair
                  • Mar 2008
                  • 24
                  check
                  1.DC Control pcb
                  • petrus
                    • 155
                    dc control pcb,power supply, ip pcb all are tested.
                    • jprecht
                      • Dec 2008
                      • 104
                      ok has got to be your boot chip or hdd if you have changed all others. Is possible you have a poor contact on door interlock switchs have been fooled by these befor jumper across each one and eliminate. is 1:00am here will admit brain not @ full strength good luck!!! j
                      • irtek
                        • Jun 2009
                        • 112
                        It sounds like the machine is in download mode. Remove the cover for the primary corona and above the corona you will see a parallel printer connector, this is used for flashing the machine not a printer port. I can't remember exactly where but somewhere around that connector is a small switch, one direction says download and the other I think says copy, you need the switch set opposite of download.
                        • jprecht
                          • Dec 2008
                          • 104
                          d mode
                          is possible but display would read "download mode" on later canons it does and you access by key sequence on cnt pnl j
                          • irtek
                            • Jun 2009
                            • 112
                            This machine is not like the later models. It does not display download mode and download mode is not accessed from the control panel.
                            • jprecht
                              • Dec 2008
                              • 104
                              defer
                              sounds like irtek knows this box. is why this job keeps you jumpin. learn something new everyday!!! good luck j
