irc 3200 color displacement.
  • smiley
    • Aug 2008
    • 616
    hi guys got a problem in this machine when i used crohme coate paper.a heavy paper but if i make one copy at a time there is no displacement in color but when i do multiple copy it got color displacement i already clean the itb assy.i already up grade the system any help please.
    there is no glory without sacrifice
  • Van Steal
    • 177
    there is a setting in service mode level two under option body "CLR SHFT" set this to 1 it will slow the printer down by 1/3 by not feeding the card in the m/f untill the first page has left the fuser. Also if ur feeding more than 250 gram card it will cause this fault
    • Kopyrtek
      Copier Psychologist
      • Jan 2007
      • 407
      You never said if you cleaned the ITB rollers or replaced the ITB belt.On this model you have to clean the rollers and replace the ITB non schedule.
      • smiley
        • Aug 2008
        • 616
        thanks for the reply guys.i will the setting in service mode.i clean the rollers in the itb and also the transfer belt.i have two machine doing this one has 200k on it the other one is just 70k on the counter.when i try to feed from the cassets i works well but it always jam because of thickness of the card.again thank you guys i will post back for the update.
        • Oze
          Ricoh Fanboy
          • 1663
          Chroma-coat or other coated boards will NOT work in the machine.
          I've had many battles with coated card over the years and they just won't fuse properly.
          • JRSC
            I print 14pt kromkote (around 307 gsm) on a c3200 all the time. It runs great. Just choose heavy 2 as your paper type. We print business cards on it, both light coverage and very heavy coverage and all works great.
            • smiley
              • Aug 2008
              • 616
              hi guys now the machine works great i turn the clr-shft to one end choose heavy two and go great thanks for you guys.but i have to ask if i remove the cleaning brush in one of my drum unit do you think the toner spill will be eliminated.i mean a back ground created by the brush when its no good.thanks.
              • SCREWTAPE
                • Jun 2025
                Originally posted by smiley
                hi guys now the machine works great i turn the clr-shift to one end choose heavy two and go great thanks for you guys.but i have to ask if i remove the cleaning brush in one of my drum unit do you think the toner spill will be eliminated.i mean a back ground created by the brush when its no good.thanks.
                If you remove the brush, it will only make matters worst..
                If you are experiencing backgrounding issues, replacing the drum
                will be the most simplest way to rectified the problem.
                • smiley
                  • Aug 2008
                  • 616
                  hi i just replece only the drum and still have the background in it.
                  • SCREWTAPE
                    • Jun 2025
                    What about transfer cleaning?
                    Have you tried the transfer cleaning blade?
                    • smiley
                      • Aug 2008
                      • 616
                      yes transfer cleaning is good only yellow has the background.
                      • smiley
                        • Aug 2008
                        • 616
                        hi guys i fund the solution i go in service mode level two and go to adjust and go to dens and adjust yellow to negative 3 and bingo the yelloiw background dis apear.i try to look at my manual but there is no dens on it under adjust in level two.
                        • Joe Karanja
                          • Jun 2009
                          • 12
                          hi,clean the inside rollers of the I.T.B thoroughly and the inside part of the Transfer Belt it could be slippery. If that does not work,try changing the internal rollers.
