how to reset the canon iR 1600 from system error E 007?
  • nikazitu
    • Aug 2025
    the canon iR 1600 shows system error e007, the replacement of film on heating unit is done succesfully and the machine was ok. then it comes again can I reset it by using any reseting procedures or i have to replace the film again?
  • Luther
    • May 2006
    • 682
    Marc is correct 1600 has fuser roller not fixing film
    • mrfixit51
      Lead Service Technician
      • Oct 2008
      • 1975
      iR 1600 shows system error E007
      Marc & Luther are correct, there is no E007 code listing for the ir1600,2000,2010 family in the sevice manual, please repost your message after re-verifying the correct model number.
      • nikazitu
        about e oo7 in canon iR.
        sory all of you.
        you are right that the machine model number was not correct but the fault was there.
        the machine is canon iR 2020 and not 1600.
        but after several time of on/off now it displays "download stanby" message only.
        i wish you help me.
        • SCREWTAPE
          • Aug 2025
          sory all of you.
          i wish you help me.
          For the E007. Did you put back the green jam release lever when you replaced the film.
          For the download standby, you might have corrupt firmware,
          or did you add a printer kit. The firmware should be v60.02 if you are installing the updated Printer Kit-J1 .
          • nikazitu
            no any kit added to iR 2020
            i didnot install, attach or add any hardware to the machine but only tried to reset the machine but unfortunately it then display the download standby
            • Guest
              Sounds like you need a new HDD.
              Do you have to reset the error code after a 007 Error?
              I think you have to.
              • pinheiro
                • May 2009
                • 51
                Download Mode
                What you need to do is to update or reload firmware starting always from BOOT then MAIN anf final OPTION, if you version is low then v15.99, please update first using a v15.99 tool, then you can use BOOT 60.02 and MAIN 64.01. Remember that all steps must to be following by switching of and on the unit pressing the botton nr 2 for service mode.
                Hope it will help
                • cosmin_mocanu
                  • Dec 2008
                  • 71
                  you need to reinstal the firmware on your machine, And for the E007 check if the new film is rotating in the same speed as the presure roller, check if you mounted the film sensor corectly, and if the sensor is reading the corect end of the film ( it schould be the one whit a white square on it).
                  • mrfixit51
                    • Oct 2008
                    • 1975
                    Dureuphosse,,,
                    Quit posting your off topic ads for illicit software in this forum. If people are interested in this, they would be looking elsewhere to find it. Very few can read this gibberish anyway...
                    • MrB
                      • Nov 2009
                      • 147
                      Looks like someone has a few problems with wireless
                      Try the other forum
                      "Help I need help with my wireless as copier techs couldn't give a crap...????!!!!"
                      • montana
                        • Aug 2008
                        • 392
                        hi...there is amistake with the model my dear..the IR 1600 does not have any fixing film it is working with the traditional teflon heat roller so it can not be 007...may you mean other model working with the fixing film method any way this error happen because of the fixing film broken or not moving right or the fixing film speed sensor has malfunctioned...i hope it is help
                        thanks
                        • Aneurysm
                          Administrator
                          • Jan 2005
                          • 1083
                          Originally posted by mrfixit51
                          Dureuphosse,,,
                          The offending user has been banned!
