IRC 3200 print problem
  • hari_4848
    • 91
    Hi ,
    In the IRC 3200 machine , I cannot see the network functions in the additional functions to set the IP address in the machine.
    How can I enable the IP address in the display ?
    Also,can the toner levels seen on the display be changed? ?
    Please help me .
    Any help is appreciated.
    Regards,
  • SCREWTAPE
    You need the printer kit I believe. The toner levels can't be change.
    • mrfixit51
      Lead Service Technician
      • 1975
      I will ask you another question...
      Originally posted by hari_4848
      Hi ,
      Please help me .
      Regards,
      I will ask you another question, does the copier have a C1 print server hanging on the back of it? If so, the ip addressing is taken care of by the C1, and you have to look at the printer information screens to get at those functions. If there is no C1 on the back of it, and you have not been able to find the Network Settings tab under Additional Functions > System Settings, then as Screwtape mentioned, this copier does not have the print kit installed in it.
      • hari_4848
        • 91
        I have the C1 kit with the machine..
        But where can I configure the IP address to take prints from the machine ?
        • SCREWTAPE
          You should see a tab called Printer on the control panel lcd.
          When you hit the tab hit functions,look for run setup. Configure the CI imagePass starting with server setup, then Network setup. This is where you configure the network protocol.
          Make sure that the C1 is at idle and not saying please wait, or any other message.
          Good suggestion mrfixit on the C1.
