Canon NP 6046 High Voltage
  • eng_usama
    • 115
    Canon Np 6045 High Voltage Give Me white paper the separation Wire in the lower corona doesn't light is there any way to fix this high voltage hope any one can help me
  • northerntech
    • Jun 2008
    • 69
    is the pre transfer the same curcit? and maybe its shotred out? it been a while since ive seen a np..
    • goofball
      • Mar 2009
      • 18
      As northerntech said. I would try pulling out the pretransfer corona assembly. And run the copier without it in the machine. If the voltage comes back than you know you have a bad pretransfer. If i doesn't it could be a bad transfer seperation corona unit. Try this first and see if this helps.
      • eng_usama
        • 115
        thanx for answer
        sorry the model is 6045
        there is something wrong in the high voltage board
        hope someone can help me to fix it
        • mata
          • Mar 2009
          • 46
          I hope you tried with another corona assy. If transfer corona works than you have charge corona problem. Separation corona doesn't affect on blank copies.
          Take out high voltage board and clean contact pins that supplies high voltage to corona. I think there is six of them. If that doesn't work probably the board is dead. I know we take this boards for some electronic service that fixses it.
          Post result...
          • eng_usama
            • 115
            many thanks
            many thanks for all ppl here machine work fine now i cleaned the high voltage board and it's fine now
