I.R.C6800
  • kings5586
    • 23
    I.R.C6800
    This Canon ir 6800 keeps rebooting in the middle of a copy or print job. I did have the main controller and dc controller out because of a toner problem E-013. I was really careful when reinstalling the boards. I check the connectors.I did not have this problem before i got there.If you have had rebooting problems on this machine,can you let me know.Just a side note they have an E-copy scan share thats throwing a 9001 code when scanning.I do not know if that's part of the problem or not. Thanks
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    Does the eCopy unit give the error before or after is scans the original?
    What I mean by that is does the error seam to be related to the "act" of scanning, or perhaps more when it goes to send the scan to folder, email, etc..,
    Another thought; did you try an MMI clear? (Be sure to back up you settings first, of course.)
    I've seen MMI clears fix all kind of goofy little issues like this.
    • SCREWTAPE
      • Aug 2025
      Well check all, connectors, boards, ETC, that were removed
      Check for pinch wires. Check Dimms, check HDD.
      What ever you took out make sure everything checks normal.
      As you said you did not have this problem before.
      Check the the connectors that supply power to the Main controller.
      • mtech
        • Mar 2007
        • 307
        Sounds like a memory issue. Try cleaning and reseating both DIMMS on the main controller. If this doesn't work, reflash the machine. If you still have the issue, replace the memory and reflash the machine. Part numbers are: WA7-3069-000 for the 256M and WA7-3157-000 for the 512M.
        • kings5586
          • 23
          Thanks for the help everybody. I'll keep working on it and let you know what fixed it. The error for the e-copy came up after i scan the document in the feeder e9001
          • mtech
            • Mar 2007
            • 307
            Just a thought because of your scanning error. Did you reboot the machine and the ecopy?
            • kings5586
              • 23
              I did correct the rebooting problem.I unistalled the main controller and dc controller and reset all the connectors. i ran the copier for two hours and the copier did not turn off.The e copy is another problem. Thanks for the help?
              • SCREWTAPE
                • Aug 2025
                Unfortunately Ecopy doesn't put there technical trouble shooting documention out there. Canon does not support Ecopy. You will have to call Ecopy or just reinstall the program, just get administrator info first.
                • kings5586
                  • 23
                  Thanks Screwtape,I'll let you know what i find out with this e copy.
                  • Canuck
                    Tech Specialist
                    • 1713
                    Reseat all RAM,DIMMS etc.....i had one do this before and it was the LVPS shutting down
