reset copier
  • chokoloz
    reset copier
    hiii..
    how to reset canon ir2016 copier?
    help need.
  • mrfixit51
    Lead Service Technician
    • 1975
    What condition are you trying to fix?
    Originally posted by chokoloz
    hiii..
    help need.
    It would be useful for us to know what you are trying to accomplish by "resetting" the copier. Do you have an error code you are trying to clear or what?
    simple answer:
    additional function key,
    2, then 8,
    additional function,
    #Clear,
    then ERR or ALL,
    if you use the ALL selection, you better have a printout of all user settings, and fax settings, and network settings, as these will be wiped out when you select Clear-ALL
    • chokoloz
      error e007
      thank 4 reset code.
      • nazmi_exa
        • Nov 2009
        • 24
        simple answer:
        2, then 8,
        #Clear,
        then ERR or ALL,
        this just clear all machine setting and back to factory setting..but its not to reset the meter..so how to reset the meter...?
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          You don't.
          • mrfixit51
            • 1975
            Only the consumable counters can be reset, like rollers and things of that nature, the copy counters are meant to show true usage life of the copier...
