ir105 keep on wait ...........
  • jiongpao
    • May 2009
    • 413
    Greetings to all pro tech. I got a machine ir105 with the problem wait ..... when i turn on the switch, it take so long like never ending. After i format and load the system file using SST the problem same when i swith it on again. Anyone can give some opinion? Thank you.
    I tried to change the main board and it show error code 000355-0001 which doesnt apply at service manual.
  • SCREWTAPE
    • Jul 2025
    Try replacing the HDD. Before you do reseat the Dimm chip.
    • jiongpao
      • May 2009
      • 413
      Thanks screwtape will try on it.
