Imagerunner c3220 With box on back...
  • dannyas
    • Aug 2025
    Lights went out other day and didn't come back for a whole day and now it won't network with my router.... I go to additianl functions and don't see anything under network connetions...
  • SCREWTAPE
    • Aug 2025
    The box on back is called a imagepass C1 or C2. In order to veiw network settings you have to hit the printer tab that's on the control panel LCD. Then hit the tab in the middle which should say printer status, after that hit functions tab at the bottom. In order to change network configurations you must scroll to run setup. If I was you I would print out a configuration page. Hit print pages then you should see configuration page.
    If you hit the printer tab and the message wait a moment or check power or check connections is posted turn down everything and reboot and hope for the best. It should come to a idle state in a mintue or less, if not then there is a problem with the imagepass. Good luck.
    • dannyas
      Yea so I got the wait a moment and won't go on now what...? lol
      • mrfixit51
        Lead Service Technician
        • Oct 2008
        • 1975
        You may now get the opportunity to reload the system software on the C1. The system software might have gotten scrambled when the power event occurred, or worse yet, the hard drive may have crapped out. I would try the system reload first and hope for the best
        • Canuck
          Tech Specialist
          • 1713
          Try unplugging the power from the imagepass and the copier...unplug it after you turn the power switches off. Plug everything back in turn it them on and wait....i've seen it take over 5 minutes to come to idle. Otherwise reload the rip software
