i Know its the hard drive is there a way to to reformat to get the machine to at least pass a copy. any help appreciated. did try the hd check
ir 3320i E000602-004
I assume that you've tried turning the machine off and on again and checked the connection between the main controller and the hdd and tried to get into download mode.
The hard drive will need to be replaced anyway so may as well do it.
