ir105 Problem
  • jiongpao
    • May 2009
    • 413
    ir105 Problem
    Hi everyone, is it possible to change whole PCB from ir105 to another ir105 machine? currently i got an error code show E000354-0002 and E000355-0001. Any pro tech know about those error code? E000354-0002 appear when i changed the pcb from other ir105 machine and format - loaded the system file. Thats why im curious about is it possible to change the PCB from other ir105 machine to another.
  • wareagle
    • May 2025
    the counter pcb has to stay with the serial pcb. sounds like you moved one of them with out the other
