Rom error
  • Peter Sim
    • Sep 2008
    • 445
    Rom error
    Hai all ,
    i got ir2000, display show "Rom Error".Machine can warm up, but panel not working.Please help.
  • demitry
    hi
    why it is not working..?
    • SCREWTAPE
      • Aug 2025
      Originally posted by Peter Sim
      Hai all ,
      When the ROM Error message is displayed on the control panel, this will indicate an issue with the Flash DIMM on the Image Processor PCB.
      In attempting to resolve the issue, reflash the system software for that specific model. If system software does not resolve the error, replace the DIMM Assembly. When replacing the DIMM, you may be required to flash the system software to it's latest version.
      iR 1600/2000 FG6-9978-000, Dimm assembly.
      As a temporary work around, power on the iR while holding down the STOP key. This may boot the iR to a ready state and copies can be made.
      • Peter Sim
        • Sep 2008
        • 445
        Thank you very much SCREWTAPE.I reflash the system software using the sst, it solve the problem.Thank you one againt for your kind help.
        • SCREWTAPE
          • Aug 2025
          No problem.
