moist copy
  • waffu22
    • Jun 2009
    • 95
    moist copy
    hi to all the readers
    a moist(erased copy) comes out every time i photo copy. aside from the paper, whats the other reason why it happen (moist)? is it the machine? if that is the problem what i'm gonna do?
    please help me...
    thanks
  • roho
    • Mar 2009
    • 844
    If you check display in service mode, you will find the humidity reading in analog, listed as a %. I've had readings of 40% during the summer-with fresh paper the out put is good. Check the readings- I believe your model comes with a cassette heater. See if it is on, working properly.
    In this region the machines don't have this heater. Some customers had to get a dehumidifier if their enviroment is constantly humid-like a basement.
    • Oze
      Ricoh Fanboy
      • Jul 2008
      • 1663
      I think he means that it's not fixing properly?
      We need a model at least....for example...if it's a 3570 series change FX-TMP to 3...for an iRC2880 change the TMP-TBL to - 2...you get the idea though...without a model number we're stabbing in the dark here..!!!
      • SCREWTAPE
        • Jun 2025
        please help me...
        thanks
        What kind of copier.. Model?
        Moisture is due to environment,
        Humidity is one cause.
        Paper and humidity, don't mix.
        When your going to run a job,
        make sure you start with fresh
        paper.
        • mitsubee
          • 176
          Did you done any adjustment on the toner tank? cleaning or dismantling the dr blade? if yes double check again on the dr blade edge...pressure spring ok?
          • waffu22
            • Jun 2009
            • 95
            paper.
            i have 5 machines which has a different model. the 3 machines are OK. and i use the same paper. the two machines which is iR5000 and iR5020 has that problem (moist). i found out that in iR5000 i check in service mode <display, analog(temp 32 degree Celsius, HUM 60%, FIX-U 2088 degree Celsius)>. the environment is OK (summer).
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              Sigh....Summer in the Philippines = High humidity.
              Paper manufactured in the Philippines,Indonesia or China have a high moisture content....this combined with summer weather causes issues.
              I know this because prior to being a copier tech I was a Guillotine operator in the printing industry and spent 30 years handling paper every day.
              Do any of the machines have large paper decks?
              The decks have a heater built in and this works well in regions with high humidity(like Northern Australia where I live).
              I'm sure you could pick one up second hand for a reasonable price.
              Just because you haven't had an issue until now means little.
              • waffu22
                • Jun 2009
                • 95
                OK... Thanks Oze
