GP605 Problem!
  • Pilotpor
    • Jul 2009
    • 30
    GP605 Problem!
    To All Pro Tech.
    I've got GP605 with problem...
    I 've got this copier for 1 year and then the dc control pcb was short circuit.
    I was order new dc control pcb and after I replaced it.
    The touch panel can not work. It show eveything but when i pressed on the touch panel... nothing responded.
  • davidj7
    • 1107
    are you having problems with the touch screen or the whole control panel?Does the numbers show on the touch screen when the buttons are pressed.
    a machine is only as good as your tech : source:screwtape ; the scary one
    • Pilotpor
      • Jul 2009
      • 30
      To Davidj7
      I having problem with touch screen.and when the buttons are pressed the numbers can show on touch screen.
      • davidj7
        • 1107
        my dear friend you need a new touch screen.Its cheap, please be careful with the cables when you put the new touch screen.
        • Pilotpor
          • Jul 2009
          • 30
          To Davidj7
          Thanks for your advice.
          OK...I'll try to replace touchscreen.
          And I'll tell you about result...
          Por
          • Pilotpor
            • Jul 2009
            • 30
            To Davidj7
            I've ordered the new touch screen and replaced it already.
            But the copier still having the same problem...
            • jiongpao
              • May 2009
              • 413
              i got a same problem before when i put in the new touch screen for GP605. I heard my friend said there is a setting for the touch screen alignment inside the service mode but i forgot where is it. You may play with it.
              In other case the wiring between the touch screen and the board must connected properly, u might need to double check because i encountered this problem before the touch screen mulfunction.
              • davidj7
                • 1107
                i have replaced touch screen didnt do any alignment just check the flat cable , see its inserted fully
                • Pilotpor
                  • Jul 2009
                  • 30
                  To Davidj7
                  I'll try it again... What do you think about this problem ?
                  The connector between Flat Cable and PCB ,The PCB or the other parts having problem?
                  Thanks to you all.
                  • jiongpao
                    • May 2009
                    • 413
                    The flat cable that connect between the touch screen and the small board that located just below the touch screen. (sorry im not sure what the board call). Turn Up side down the whole control panel and u will see the white flat cable and make sure it inserted fully.
                    • davidj7
                      • 1107
                      pilot: do what jiongpao said, thats what i usually do, other than the touch screen i had no problems with the panel of the 605.if you tighten the screws too much the touch screen wont work. just turn the screw driver till you feel pressure is required,stop there.
                      • Pilotpor
                        • Jul 2009
                        • 30
                        To davidj7,jiongpao and to all.
                        Today I've try to reseated the White flat cable and Flat cable from touch screen...The problem stay the same...
                        I don't know it will concern with the dc control pcb or system mother board? What do you think?
                        Please help me...
                        Thanks to you all.
                        • davidj7
                          • 1107
                          do you another 605 machine on which you can chedk the control panel.
                          • Pilotpor
                            • Jul 2009
                            • 30
                            To davidj7 and to all.
                            Today,I can fix this problem already.By order the other new touch screen and replaced it . Thank you very much for your help.
                            If I've another problem,I hope you all will help me...
                            Thanks again.
