so an internal say pg 10 test is ok? and all print job are ok?
i would dump evrything(as per prev making sure i had label print)
start machine without reader attached - set up machine & again test internal print are ok - then add reader & check - if still faulty then start with ccd adj after that proably give up & replace r-con
Surely your printing out a P-Print before anything is cleared. Make sure that reinput values for R-con and the white plate values.
There is a label on the top right of the glass that has a couple of numbers. If you have cleared the reader controller PCB's RAM or decide to replace the reader controller PCB, enter the values on the service label. Things to look into, would be R-con, and the CCD.
In service mode go to:
Copier>adjust>CCD
W-PLT-X
W-PLT-Y
W-PLT-Z
