Canon iR3320
  • synergymedical
    • Aug 2025
    Canon iR3320
    need a master reset, or new ip address, can any one offer assistance.
    thanks
    dmp
  • JustManuals
    • Jan 2006
    • 9838
    Is there some unknown reason you posted this twice in 9 minutes? Couldn't wait that long for an answer perhaps?
    • bnmand
      • Sep 2008
      • 383
      thanks
      dmp
      This machine is similar to the 3300 (3320 has more features, but essentially is very similar). On the 3300 to set IP address go to Additional Functions > System Settings > Network Settings > TCP/IP settings > IP address.
      You need your IP address to be in the same range as other devices on your network and same subnet mask.
      If you have a DHCP server you could try turning DHCP on. Remember to turn it off after getting a new IP address. Once you've made your changes turn the copier off using main power switch (on right hand side) and on again. Go back in and see if the changes have worked.
