IRC 5185
  • Chaw
    • Mar 2009
    • 48
    IRC 5185
    Morning I have an IRC 5185 that I am having power issues, when I turn the machine on it boots like normal and goes to the then home screen. during the warm up process the Copier makes a weird noise like a crackling noise then the Copier shuts off, but the little black switch on the left side of the copier if you are facing the copier trips to the off position. there is no error code or no warning it just cuts off if I flip that little black breaker like switch the machine comes back on and does the same thing everytime. Not sure if anyone can point me in the right direction spoke to some other sr techs and they said that they never ran into a problem like that. Thanks in advance for all your help.
  • SCREWTAPE
    Look around the fuser section, check out the fixing unit.
    • Canuck
      Tech Specialist
      • 1713
      Try to get into service mode if you can and check the error log
      • roho
        • Mar 2009
        • 844
        I had the exact senario on a 3200 a week after a fuser rebuild. Swapped the old unit in for test purposes, and the machine booted up.
        It would be the first place I would test.
        • Oze
          Ricoh Fanboy
          • 1663
          I went to a 5180 2 weeks ago with EXACTLY the same issue...crackling sound and tripping the circuit breaker.
          The Upper fixing belt is torn...better order a new fixing unit if you don't have one on hand.
          • nivssluck
            • May 2008
            • 228
            Did you solve the problem Chaw?
            • Chaw
              • Mar 2009
              • 48
              Fixing Unit Belt
              Thank you guys it was indeed the upper fixing Unit belt that was thorn and making the noise, so replaced the Fixing Unit Copier working great.
              Thank you.
              • Magebomba
                • Dec 2008
                • 92
                I was at class 2 weeks ago as well Oze, eastern region.
