E100 on IR105
Make sure the laser shutter is opening completely. It is actuated by the front door interlock. If the interlock is loose or the actuator plate is bent (which can happen if the door has been interlocked manually) it will not make good contact and the shutter won't open all the way causing intermittent or consistent e-100 codes.Is the glass half full or half empty? I say neither. The glass is obviously full, full of potential. The potential to hold more water or the potential to quench a thirst. Life is all about how you see it.
