iR2270 Format HDD
  • Peter Sim
    • Sep 2008
    • 445
    iR2270 Format HDD
    Hai all, need help and advice.
    I have ir2270 software.My machine show error code e602-0001.
    I put in a sumsung "NEW" 40G HDD into the machine.Using SSt to download>>ALL>>Start Batch Download>>Execute HDD Format>>Could not get TargetInfo.txt due to HDD problem.
    I can't format the HDD,what due to the problem?Thanks.
  • bnmand
    • Sep 2008
    • 383
    Canon has a file containing a list of supported drives. This list is encrypted. So the SST HDD not found procedure posted by Oze that works for older models will not work. You have to use a drive on the list. Get the exact same model as a drive already in the machine or buy a new hdd that works in the machine either from Canon or if you know the manufacturer's model no. from somewhere else.
    Canon encrypted the list because they want to make money, they don't want you to buy disks from someone else
    • Peter Sim
      • Sep 2008
      • 445
      Thanks bnmand. can i have the Oze link to the list.
      • JustManuals
        • Jan 2006
        • 9838
        Why don't you just search for it?
        • Oze
          Ricoh Fanboy
          • 1663
          Here it is again...lucky I keep copies
          The list of drives that bmand was referring to is actually contained within the system software for the HDD...the .itf file.
          This procedure shows you how to open it so that you can view the list of compatible HDD.
          What he says is 100% correct...you cannot edit this particular .itf file however as Canon have encrypted it.
          I'm on leave at the moment but due to head back to work on Monday...I HAVE heard a rumour in Tech Services that this file CAN be edited and I'll do a little smoozing and see if they'll let me know the procedure.
          • j2980kh
            • Mar 2009
            • 69
            Hard clones use. SATA , SATA2 IR3245, IR4570, IR105+ TEST OK
            4shared.com - file sharing network - free file search - hdclone
            • Oze
              Ricoh Fanboy
              • 1663
              Rather than just posting links to software(which is all I've ever seen you do by the way) why don't you give a description of what the software does,how to use it etc..
              For example...I'm guessing from the name of the file that it's a ghosting program.
              I also guess that it will ONLY work if you buy exactly the same model drive as the one already in the machine because,as we've said a million and one times,you cannot use any other drive than the ones contained in the .itf.
              In future just don't post a link to a file without a description please...especially one from a filesharing site....they're a hotbed for malware.
              • j2980kh
                • Mar 2009
                • 69
                RapidShare: 1-CLICK Web hosting - Easy Filehosting free software
                V3 Vaccine program Check said. documentation in the file. Maybe you'll understand enough. 1:1 copy program.
                • Oze
                  Ricoh Fanboy
                  • 1663
                  Like I guessed it's probably a ghosting program.
                  My gripe is posting blind links to software...seems lazy to me is all.
                  • bnmand
                    • Sep 2008
                    • 383
                    I agree. No point linking to software without giving some explanation of what to do with it.
                    • j2980kh
                      • Mar 2009
                      • 69
                      확실히 된다. 나도 설명서를 보고 했다. 그게 어려우면 동영상으로 올려줄까?
                      너무 답답하다. 대충보면 알수 있는 프로그램인데 어려운것도 아니다.영어로 장문의 글로
                      쓰기가 너무 힘들다. 이건 말로 설명할수가 없다.
                      • JustManuals
                        • Jan 2006
                        • 9838
                        That's easy for you to say.
                        • bnmand
                          • Sep 2008
                          • 383
                          And not so easy for the rest of us to understand Korean.
                          Google translates it as
                          "Be sure. I reported the documentation. If you want to put a video that difficult?
                          Dapdaphada too. I know it is not a program is roughly eoryeoungeot. English, written by long
                          Too difficult to write. It does not explain it."
                          • Peter Sim
                            • Sep 2008
                            • 445
                            Thanks Oze,for your links.Do you have any info,could you let me know about it?Cause we cannot found the HDD drive as the same with the copier any more.
                            • mrfixit51
                              Lead Service Technician
                              • 1975
                              Here it is again...
                              Hi Peter,
                              As more than one person has mentioned,, due to the fact that the format .ift file is encrypted, the ONLY two options are to research the model you currently have in the machine, or buy one from Canon. FM2-4907-000 is the part number I have, and the drive enclosed in that box is HTS541640J9AT00. We can be no more specific than that.
                              Good luck!
