E000002-0102 power problem? Whats the solution? thanks
Change the complete fuser assy as one of the themistors has gone open circuit,just by ordering up the single parts costs the same as bbuying the complete thing if ufr and lfr are required,reset the code *28* function ,clear ,error,hope that does the trick,regards Steve c
I put a fuser assy in but can't seem to get it into service mode now.
Any Ideas why it wouldnt go?
thanks again
you still have the error. After error released, the copier would boot up normal, but the error is repeating. May not be the fuser- I have gotten e002, e004 errors from the sensor/micro switch assembly that mates with the fuser when the tray is pushed in. That area needs to be cleaned of caked toner, and dust. If 2 different fusers are giving the same problem, I would check that area!
