i need to print onto paper that is 120mm x 240mm through the bypass in a 1024if BUT without having to type in the size in "freesize" on the copier all the time.
I have set up a print driver so that it automatically picks the custom paper size and bypass on the driver. but we dont want to have to select freesize then type in 120 and 240 on the copier..
any ideas???
have tried putting it through as different sized envelopes and stuff but it wont work.
any ideas???
