ir 3300 curled paper
  • lightningjeremy
    • Jul 2009
    • 139
    here in sunny florida, i have many cutomers with humid paper. most machines deal with it pretty well accept when it comes to duplexing. i try to explain to the customers how humid paper curles when it is heated in the fuser and this problem is amplified on duplex, but i think sometimes the wall would understand better! i turn the fuser temp down to try and help, but that only goes so far. is there anything else i can do? i know its not the fault of the machine, but the customers just dont get it! thanx
  • andy21557
    Help Desk Technician
    • Jul 2009
    • 62
    moisture in paper
    have you tried runing the paper in the short edge feed .. LTRr direction ?
    • davidj7
      • 1107
      during monsoon some customers pre-heat the paper , ofcourse its practical only if volumes are low. You could also switch paper with less water content. Might go haywire with the costs but would get the job done.
      a machine is only as good as your tech : source:screwtape ; the scary one
      • lightningjeremy
        • Jul 2009
        • 139
        ltr r is more reliable, but getting the customer to understand why is a whole other thing!
        • sgcopiertech
          It's very difficult for customers to accept that the environment can be a very huge factor in the reliability of a machine...
          • Guest
            I had a problem with paper.
            I got a fresh packet of there paper and after 2 copies I had a PJ.
            I got a fresh packet of better quality of there paper and ran 200 copies no PJ.
            Then I said see and they said oh yes!
            If they have a paper problem not much you can do but arm yourself with better paper and show them.
            • Guest
              Originally posted by marc.lucas
              Tell them to get air con! surely they need it anyway!?
              And the UK needs some Sunshine!!
              • montana
                • Aug 2008
                • 393
                hi.i think there is a technical solution for this by installing the cassette heater.i don"t know if it is available for this model or not
                thank you............
                • deepmani
                  • Jun 2009
                  • 6
                  Heat the papers by putting them in a cardboard box with a 40W incandescent bulb installed in it. The bulb should be at least 2 inches above the paper. This will solve your problem.
